Re: 1966 L79 with A.I.R. optimum tune up specs
I decided to run some additional tests to figure out what was going on with ported vacuum, total crank advance, and exhaust manifold temperature, and learned that the advance can , connected to ported vacuum, at 800 RPM idle, is actually producing total crank advance of 25 degrees. I also checked exhaust manifold temperatures again, this time holding the IR gun much closer to the manifold (about 3 inches).
Before I started these tests, I again rechecked initial timing at about 600 RPM which is about the lowest I could get it to idle. It was spot on at 10 degrees BTDC.
Here are the readings: (All measurements were taken at 800 RPM)
With ported vacuum connected to the advance it measured 7", total advance 25 degrees, temperature 495 degrees.
With ported vacuum disconnected and plugged, it measured 12", total advance 14 degrees, temperature 590 degrees.
Then I connected the mityvac to the vacuum advance can in order to control vacuum to the can and got these readings:
At 4" vacuum, ported vac was measuring 12", total advance 14", temperature was 570 degrees.
At 6" vacuum, ported vac was measuring 10", total advance was 17 degrees, temperature was 500 degrees.
At 8" vacuum, ported vac was measuring 5", total advance was 24 degrees, temperature was 500 degrees.
At 10" vacuum, ported vac was measuring 2", total advance was 30 degrees, temperature was 470 degrees.
I think what this means is:
The centrifugal is kicking in about 4 degrees of crank advance at 800 RPM.
The advance can is doing it's job of producing 25 crankshaft degrees at 800 RPM.
Exhaust manifold temperatures are down about 100 degrees F with 25 degrees of advance compared to 10 degrees.
The ported vacuum measurements are a function of throttle plate position - as I had to adjust engine RPM whenever I changed vacuum to the advance can.
I'm going to install the lighter springs and recheck these measurements to see what effect the springs have. But at this point I've got the idle characteristics in good order. After flight judging, I'll convert the car to full vacuum and make sure real world driving performance is OK.
I ordered a Standard Motor VC-171 which is supposed to be an equivalent to a B22 can for the '67. I could not find a Delco D1308C or a NAPA VC-1802. When I get that advance I'm going to work on converting that car to full vacuum.
Bob
Bob
