I am cleaning up the cowl wiring on my 58. We replaced the complete nose 30 years ago. Back then I glued the wiring clips to the inside lip area just like it was on my 62. Now I am correcting my own 'Bubba'ing.
According to the 58 AIM this clip should be riveted. Before I drill the holes for the rivets I want to be sure that's how the 58s were done.
I was going to use the same rivets used for the nose support rod brackets even though the AIM calls out 2 different part numbers. According to the AIM Sect B Sheet 2. the rivet for the 37463404 rod bracket was part number 455624. Section 12 Sheet 2 left side calls out a 9409244 Rivet (see picture)
So is it riveted?
And if so are the two rivets 455624 and 9409244 similar so the current repop rivets for the bracket close enough?
Thanks Eric
So is it riveted?
Thanks Eric
