I used DOT 5 brake fluid when I restored my 66 (non-power), i.e. new lines, rebuilt calipers and rebuilt master. I only have 300 or some miles on the car, but I've been happy with the brakes and had no trouble bleeding the system.
I'm in the process of installing new brake lines on my 67. I also have the calipers off and apart for cleaning and new seals. I will also be taking master cylinder apart for cleaning. This car had Dot 3 fluid in it when I got it. I had an accidental fluid spill at the master cylinder and of course lost paint on the master cylinder, bracket and firewall. Not major just irritating, so I was planning to switch to DOT 5 with all the working I'm doing on the car.
Now here is the rub. I was ordering some parts from Corvette Stainless Steel Brakes and saw a warning on the upper left of their web pages Dot 5 Brake Fluid Will Void Warranty. If you click on this warning it brings up a page (see attached PDF). This page also has a link to an EPA document. That EPA document relates to ethylene glycol ethers and not silicone base products, so I'm not quite sure what that document has to do with CSSBs warning regarding Dot 5 fluid.
If CSSBs test is accurate (see the PDF attached) it shows quite a bit of swell in the rubber seal.
I really like the idea of Dot 5, i.e. non-hydroscopic and doesn't remove paint, but now I'm wondering if it is wise to use Dot 5.
Is the any validity to CSSBs warning and does it raise concerns with any other Dot 5 users?
Don
Don
