Something interesting on my '68 - NCRS Discussion Boards
  • Richard M.
    • September 1, 2016
    • 36
    I'm sure I'm not the only one whose seen this but thought I'd share just the same.
    '68 SB roadster, 54K unrestored original miles.
    After removing springs, I noticed what appears to be some left-over slag from production in the upper spring well on the passenger side, about 1/4" in length. There's a corresponding wear mark on the upper coil of the spring which apparently indicates the left side spring was never seated since the car was produced.
    Re: Something interesting on my '68
    Richard------
    Yes, it appears it's just as you mentioned. However, I don't think this would have resulted in any big problem---just an example of poor quality control of the period.
    A bigger problem for you now is the rather severe corrosion of the spring tower I can see in your photo. In one area it even looks like it's perforated the steel. This problem might also be found in other areas of the frame and chassis.
