427-390 w/air fan shroud - 1967 - NCRS Discussion Boards
  • Jeff B.
    • April 30, 1980
    • 165
    Does anyone know if a reproduction fan shroud is available for this combination? Where might I find one?
    1967 Coupe 427-390 w/air
  • Joe R.
    • July 31, 1976
    • 4547
    Re: 427-390 w/air fan shroud - 1967
    Yes, they are available. You will need the 427 Fan Shroud (Correct Fiberglass) Approx. $395.00 and a 427 w/ac Fan Shroud Extension along with the bolt w/UNut Set.
    Available at all the big box warehouse sales.
    CC numbers are: 242036,242070 and 242059
    JR
    • Larry M.
      • January 1, 1992
      • 2688
      You might also be able to source an original if you want to spend the extra $$$. David S. in California is one place to check. David Crane in California is another.
      Larry
      • Jeff B.
        • April 30, 1980
        • 165
        I will look at both options. The only "part" I need is the shroud. The A/C belt broke, and when the "dust had settled", it cracked the shroud on the top of the drivers side. Is still all together in one piece, and can probably be repaired fairly easily, just am unsure how to blend in repair to match rest of the shroud.
        • Larry M.
          • January 1, 1992
          • 2688
          You might give Scott Sinclair a call. He repairs the tire tubs and heater boxes and other misc fiberglass parts. He did my tire tub and work was excellent.
          I assume Scott is still doing this work..........as it has been a few years since I last used him.
          Larry
