Does anyone know if a reproduction fan shroud is available for this combination? Where might I find one?
427-390 w/air fan shroud - 1967
Re: 427-390 w/air fan shroud - 1967
Yes, they are available. You will need the 427 Fan Shroud (Correct Fiberglass) Approx. $395.00 and a 427 w/ac Fan Shroud Extension along with the bolt w/UNut Set.
Available at all the big box warehouse sales.
CC numbers are: 242036,242070 and 242059
JR- Top
I will look at both options. The only "part" I need is the shroud. The A/C belt broke, and when the "dust had settled", it cracked the shroud on the top of the drivers side. Is still all together in one piece, and can probably be repaired fairly easily, just am unsure how to blend in repair to match rest of the shroud.1967 Coupe 427-390 w/air- Top
You might give Scott Sinclair a call. He repairs the tire tubs and heater boxes and other misc fiberglass parts. He did my tire tub and work was excellent.I will look at both options. The only "part" I need is the shroud. The A/C belt broke, and when the "dust had settled", it cracked the shroud on the top of the drivers side. Is still all together in one piece, and can probably be repaired fairly easily, just am unsure how to blend in repair to match rest of the shroud.
I assume Scott is still doing this work..........as it has been a few years since I last used him.
Larry- Top
