Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 68 L71 Center Carb Base Gasket - NCRS Discussion Boards
  • Rich G.
    • August 31, 2002
    • 1396
    I need this and one for the rear carb. The shop where my car is says they are having trouble finding these gaskets.
    Any and all suggestions appreciated.
    Rich
  • Leif A.
    • August 31, 1997
    • 3607
    Re: 68 L71 Center Carb Base Gasket
    Rich,
    The good Doctor has them...
    Web catalog of 700+ pages, 1000+ illustrations, 12,000+ Corvette restoration parts available mail order. Dr Rebuild Corvette Products manufacturing & distributing parts for 1953-1982 models for 22 years.
    Leif
    • Rich G.
      • August 31, 2002
      • 1396
      • Chris H.
        • April 1, 2000
        • 837
        Rich, the base gaskets come as part of the Holley 2300 rebuild kit.
        • Rich G.
          • August 31, 2002
          • 1396
          Thanks Chris
          • Mark G.
            • January 31, 2007
            • 177
            These are on the Docs website: http://shop.docrebuild.com/1967-1969...GM3921922.aspx
            I believe all 3 gaskets are the same and the center carb gasket gets turned top for bottom.
            • Ray K.
              • July 31, 1985
              • 369
              Rich
              LI Corvette supply shows a set of - 3 - in their catalog.
              • Rich G.
                • August 31, 2002
                • 1396
                • Rich G.
                  • August 31, 2002
                  • 1396
                  • Chris H.
                    • April 1, 2000
                    • 837
                    Rich, just curious, what makes you think you have a vacuum leak?
                    Also, with all the flare fittings on a tri-power, if you're not already using them, I highly recommend flare gaskets:
                    Makes leak free flare fittings a breeze.
                    • Rich G.
                      • August 31, 2002
                      • 1396
                      The vacuum leak presents itself as a high pitch whistle at idle. Also a smoke test showed it and spraying carb cleaner at the base of that carb caused an RPM increase.
                      Rich
                      • Danny P.
                        • Today
                        Direct from Holley, kit # 37-396
                        • Rich G.
                          • August 31, 2002
                          • 1396
                          • Danny P.
                            • Today
                            Good luck finding those paper Thin Black base gasket, those were the factory gaskets closest very thin one to factory are in Holley kit 37-396 very dark gray or find the black gasket paper your looking for and make your own,
                            • Daniel S.
                              • February 1, 2000
                              • 164
                              These are the 2 base gaskets that come in 37-396 Holley kit. The smaller gasket, which I believe is correct for L71 application, is thinner than the bigger gasket. Both are paper though.
