Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
amp gauge -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I have a 66. i was working on the horn rely and it sparked when one of the hot leads grounded out. Dumb me for not disconnecting the battery. Now the amp meter is consistently discharging but when i check the battery it is charging 14.2 volts. Is there a fuse in line that i blew? Did i burn out the amp meter?
Mel
In theory it is possible to run the shorted current through the amp meter in the situation you described.
The gauge is really a voltage meter not a amp gauge as listed but that's another story.
Another test it to go from one amp gauge terminal to the other with the measuring meter set to 5V or less.
With the motor off:
With the low beam headlights on it should read a nominal .16V
With the high beam headlights on it should read a nominal .2V
If the readings are anywhere close to these readings the circuit is good.
If the voltages (lead to lead) are somewhere close to the above readings (nominal) it is likely your Amp gauge is defective.
It is more important the readings change when the load changes than what the exact reading is.
The last test I use is a used 1.5 V battery attached to the leads of the amp gauge.
1.5 volts will peg the gauge that's the reason a used battery works better.
Polarity will not matter it just moves the gauge to the - or + side of the gauge.
