Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508 Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510 Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737 Warning: Undefined array key "online" in .../vb/library/content.php on line 3522 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614 Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165 Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182 Warning: Undefined array key "posts" in .../vb/api/user.php on line 183 Warning: Undefined array key "posts" in .../vb/api/user.php on line 189 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480 Warning: Undefined array key "userid" in .../vb/api/user.php on line 204 Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246 Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342 Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594 Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610 amp gauge - NCRS Discussion Boards
amp gauge
  • Mel S.
    • August 31, 1992
    • 263
    amp gauge
    I have a 66. i was working on the horn rely and it sparked when one of the hot leads grounded out. Dumb me for not disconnecting the battery. Now the amp meter is consistently discharging but when i check the battery it is charging 14.2 volts. Is there a fuse in line that i blew? Did i burn out the amp meter?
    Mel
  • Danny P.
    • Today
    Re: amp gauge
    Check if your horn works you could of blown a fuseable link on the relay harness or starter harness
    • Mel S.
      • August 31, 1992
      • 263
      Re: amp gauge
      The horn works along will all of the other electrical in or on the car
      Mel
      • Danny P.
        • Today
        Re: amp gauge
        Check voltage behind the amp meter at both rear post you should get the same voltage you get at the battery 14.2 if you do the amp meter is done
        • Richard G.
          • July 31, 1984
          • 1715
          Re: amp gauge
          In theory it is possible to run the shorted current through the amp meter in the situation you described.
          The gauge is really a voltage meter not a amp gauge as listed but that's another story.
          Another test it to go from one amp gauge terminal to the other with the measuring meter set to 5V or less.
          With the motor off:
          With the low beam headlights on it should read a nominal .16V
          With the high beam headlights on it should read a nominal .2V
          If the readings are anywhere close to these readings the circuit is good.
          Rick
          • Mel S.
            • August 31, 1992
            • 263
            Re: amp gauge
            Thanks - i will give it a try. You are right it is a volt meter - my error
            • Richard G.
              • July 31, 1984
              • 1715
              Re: amp gauge
              If the voltages (lead to lead) are somewhere close to the above readings (nominal) it is likely your Amp gauge is defective.
              It is more important the readings change when the load changes than what the exact reading is.
              The last test I use is a used 1.5 V battery attached to the leads of the amp gauge.
              1.5 volts will peg the gauge that's the reason a used battery works better.
              Polarity will not matter it just moves the gauge to the - or + side of the gauge.
              Best of luck.
              Rick
