broken push rod
Re: broken push rod
What does "...rotation of the pushrod end, "for-and-aft" within the socket of the rocker arm" mean?Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
Re: broken push rod
Joe?- Top
Mark Edmondson
Dallas, Texas
Texas Chapter
Re: broken push rod
Take an un-installed pushrod and rocker arm and move the pushrod "fore-and-aft" in the rocker ball "socket" of the rocker arm.
Also, it's not 180 and 270 degrees; it's "180" and "270" degrees.In Appreciation of John Hinckley- Top
Re: broken push rod
https://www.forums.ncrs.org/showthre...hlight=Dingman
Bruce: The discussion about my broken valve spring was moved by Don Hooper after I made the reference in post number 6 above. I should not have put it under the Altoona Regional discussion, and I don't mind that he moved it. If you have not yet found it, and still want to look, see the link just above this added comment.https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
