Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Tonawanda 427-435 JE Stamp Pad -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
What was the average amount of 427 L71 JE Stamp Pads were Stamped per Day at the Tonawanda Plant and how many workers at the plant were Stamping Engine Pads throughout a shift per day.
For The Tonawanda Mark IV motors the assembly stamp was applied before the head(s) were installed, but I would expect the engine build was in most cases completed on the same day.
So the engine get drop in the Chassis with no Vin. # in St Louis then a worker on the assembly line Stamps the Vin# on the engine before the body is drop.
Not quite. The VIN was stamped on the engine and transmission on the line where they (engine and transmission) were mated. After that they were installed in the chassis.
Engine Dress Line
Hang engine and transmission
Stamp VIN
Install Accessories
Engine oil and transmission fluid
Send to chassis line
Here is a picture Mike Hanson had of the VIN stamp being added in St. Louis:
Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)
Thanks Micheal, perfect that all I wanted to figure out how the Vin.# was Stamp and engine stamp was done , So at Tonawanda plant the engine date Stamp was done without the heads on then engines were completed then ship to St Louis , Engine and Transmission were join together then dress up Vin.# stamp then to the Chassis line , thank you
I guess at the Tonawanda engine plant there was alot of Stamping Pad being whacked and I,am very surprise after stamping so many engine per day my guess is about 300, so how could it be possible that the stamping numbers meaning "Engine Stamp pad" at that particular day "claim" that all stamping pad should look the same in that certain day Claiming as of a fingerprintmark, the gangland holder after taken a beating like that all day by different day and night workers wouldn't you think the gangland fonts numbers & letters would wear or chip or been replaced and the spacing of the numbers changes and the depth of the sledge hammer hit's through out the day changes the look's of each and every stamp Pad done after so many whacks that day .
