Warning: Undefined array key 24282 in .../vb/library/content.php on line 3508
Warning: Trying to access array offset on value of type null in .../vb/library/content.php on line 3510
Warning: Trying to access array offset on value of type null in .../vb/user.php on line 737
Warning: Undefined array key "online" in .../vb/library/content.php on line 3522
Warning: Trying to access array offset on value of type bool in .../vb/library/user.php on line 614
Warning: Undefined array key "birthday_search" in .../vb/api/user.php on line 165
Warning: Undefined array key "joindate" in .../vb/api/user.php on line 182
Warning: Undefined array key "posts" in .../vb/api/user.php on line 183
Warning: Undefined array key "posts" in .../vb/api/user.php on line 189
Warning: Undefined array key "userid" in .../vb/api/user.php on line 6480
Warning: Undefined array key "userid" in .../vb/api/user.php on line 204
Warning: Undefined array key "privacy_options" in .../vb/api/user.php on line 246
Warning: Undefined array key "userid" in .../vb/library/user.php on line 5342
Warning: Undefined array key "userid" in .../vb/library/user.php on line 1594
Warning: Undefined array key "lastactivity" in .../vb/library/user.php on line 1610
Tonawanda 427-435 JE Stamp Pad -
NCRS Discussion Boards
If this is your first visit, be sure to check out the FAQ You must be an NCRS member before you can post: click the Join NCRS link above to join. To start viewing messages,
select the forum that you want to visit from the selection below. If you have trouble logging in you can clear your cookies here!
I guess at the Tonawanda engine plant there was alot of Stamping Pad being whacked and I,am very surprise after stamping so many engine per day my guess is about 300, so how could it be possible that the stamping numbers meaning "Engine Stamp pad" at that particular day "claim" that all stamping pad should look the same in that certain day Claiming as of a fingerprintmark, the gangland holder after taken a beating like that all day by different day and night workers wouldn't you think the gangland fonts numbers & letters would wear or chip or been replaced and the spacing of the numbers changes and the depth of the sledge hammer hit's through out the day changes the look's of each and every stamp Pad done after so many whacks that day .
I believe you are correct. I have said it before I have stamped CI a lot when I was a patternmaker. Iron is hard & not very malleable & would dull the sharp edge of the stamp quickly. If some of the characters were used before & some Fairly new some would be changed some not.
Ken, I have seen 4 the Same Dated Tonawanda 427 Stamping pads blocks that were all stamp the same day at the Tonawanda plant but all 4 Stamps pad look Different , and all 4 Stamping pads are 100% Original, so if someone has a Library of Stamping pad for a certain date and if someone wanted to confirm there Stamping pad with the one's in the Library claiming it a "Finger proof comparison" how would they compare it with if the stamp pad is real or not if there's 4 different samples of the stamp pad done on that same particular date, i agree what your saying Ken the character on the gangland holder do get dull after all those whacks and the character get change with different fonts from different suppliers, so how could it be possible that certain stamping pad would look all the same at that particular date .
Where are you getting your information from to make the assumptions implied?
Some information i,am getting is from Tonawanda plant site explaining how the Stamping pad daily procedure is done at the plant explaining exactly what i ,am saying, i,am also gathering Stamping pad Information and photos from 427 Corvette owners for a Particular date that i,am researching and i,am seeing a differents in every Stamp pad photo, maybe you can explain Gene why theres a differents in stamping pad done on that particular day I,am going by the photos that i,am seeing.
