The owners' manual for my stock '62 340 hp 327 states "6 qts oil capacity with filter change." This correct? When and for what small blocks did it change to 5 qts with filter?
'62 engine oil capacity
Tags: None
- Top
Re: '62 engine oil capacity
Thanks. And to all who still have the canaster type filter, be sure to remove old gasket and install new one or you'll have a nasty oil leak.- Top
William-------
For 1963 the Corvette oil pan configuration changed dramatically from the C1 era. For 1963-74 small blocks there were 2 different oil pans used depending upon year and engine application. The "standard" configuration pan was for systems with 5 quart capacity with filter change. A differently configured pan was used for all 63-65 mechanical lifter applications as well as 1970-72 ZR-1. This pan was used with systems with a 6 quart capacity including filter change.In Appreciation of John Hinckley- Top
