1967 Steering Wheel Collar Date - NCRS Discussion Boards
  • Keith B.
    • September 15, 2014
    • 1575
    Re: 1967 Steering Wheel Collar Date
    nope not the same
    • Neal K.
      • October 31, 2007
      • 303
      Keith,
      Thanks.
      Neal
      • John D.
        • June 30, 1991
        • 874
        #18
        For another data point my late October '66 (after the strike) survivor type car has no date at all on the collar. It seems this and some other parts including jacks had date codes that started with the beginning of the 67 calendar year. Was there a rule that changed or just a coincidence ?
        • Jeff B.
          • April 30, 1980
          • 165
          #19
          My January 23rd (F23) built coupe is dated 04 7
          1967 Coupe 427-390 w/air
          • Michael V.
            • May 31, 1995
            • 73
            #20
            Does the dates on the column also apply to telescopic columns also?
            Mike
            • Jeff B.
              • April 30, 1980
              • 165
              #21
              Originally posted by Brian McHale (28809)
              MY Jan 67 build has a dated collar 361 6.
              Brian:
              What was the completion date on your car?
              Mine was Jan 23, with collar date of 04 7
              Jeff
              • Brian M.
                • February 1, 1997
                • 1837
                #22
                January 7th.
                • Peter M.
                  • May 30, 2013
                  • 358
                  #23
                  Mike
                  Mike,
                  My April 17th car with telescopic is stamped 095 7.
                  • Robert B.
                    Infrequent User
                    • November 15, 2019
                    • 4
                    #24
                    My 67 Vette (standard steering column) with a build date of Nov. 22, 1966 has no date code on the steering wheel collar. It also has a 1966 power brake booster. I believe that both are original.
                    • Leif A.
                      • August 31, 1997
                      • 3607
                      #25
                      Robert,
                      Welcome to the TDB...and, Happy Holidays. You are replying to a thread that is 3 1/2 years old. If you read post #5, you will see why your column does not have a Julian date code.
                      Leif
                      • Robert B.
                        Infrequent User
                        • November 15, 2019
                        • 4
                        #26
                        Hi Lief,
                        Thanks for the quick response. I did realize that the thread was 3.5 years old. I did not want to start another one since the topic seemed to be somewhat covered. I do read old threads. They are a great source of information for a beginner like me. So, I added my 2 cents worth to an old thread. Also, I did read post number 5 before I posted. I had looked at the 7th edition of the 1967 Judging Guide and there is no "option" for a non-dated collar. Based on that guide, my collar would not be OEM. Since the 7th edition, supersedes the earlier ones, I felt I had to ignore the "non-dated" option that was mentioned in an earlier version. Thanks for your help on this. I will need your guidance in the future. There is much foe me to learn.
                        • John D.
                          • June 30, 1991
                          • 874
                          #27
                          Originally posted by Keith Kolerus (48481)
                          My Oct. 1966 car does not have a date code on this collar.
                          Nor does mine...
                          • Gary T.
                            Infrequent User
                            • April 30, 1994
                            • 13
                            #28
                            I have access to 2 67's to add to the discussion:
                            COUPE- #12852 has column dated 363 6, build date 3/7/67
                            CONV - #18301 has column dated 123 7, build date 5/11/67
