Identify rear springs - NCRS Discussion Boards
  • David H.
    • November 11, 2009
    • 777
  • Don H.
    • December 1, 1981
    • 1482
    Re: Identify rear springs
    David, Do you have the current 58-60 Technical Information Manual & Judging Guide (new - 5th Edition available from the store)? It has a detailed summary and pictures starting on page 314. This is the first NCRS Judging manual in color (I think) and well worth the cost - many thanks to the revision team! Besides being original or not, they could have been re-arched incorrectly. Don H.
    • Terry D.
      • May 31, 1987
      • 2690
      Does your 61 or 62 have 4 leaves or 5? In the last picture it appears you have 5 leaves, if this is so it will be very stiff. I know 5 leaves were an option on some cars but did the 5th leaf also have the same grooves as stock 4?
      • Joseph L.
        • July 26, 2012
        • 160
        This is not a stock leaf set. There appears to be 4 leaves, however it appears the ends of the three lower leaves were torch cut. I had added an extra leaf to a set of springs by cutting the eyes off the main leaf on a 55 Chevy. If these individual leaves are longer than the stock springs, the spring bundle will be stiffer. The lowest leaf is much longer than a stock leaf. Also, the ends of stock lower leaves have a thinner section about 3" long.
        You may want to look for a set of stock springs and send them to Eaton for reconditioning. I did that to a set and had good results.
        Joe
        • David H.
          • November 11, 2009
          • 777
          • Joseph L.
            • July 26, 2012
            • 160
            I PMed you.
            • Terry D.
              • May 31, 1987
              • 2690
              is there 5 leaves in the last picture or are my eyes going bad?
              • David H.
                • November 11, 2009
                • 777
                • Terry D.
                  • May 31, 1987
                  • 2690
                  It appears that only the bottom leaf is not grooved, is that correct? If so all you need is that leaf.
                  • David H.
                    • November 11, 2009
                    • 777
                    Looking at a new set of rear springs from SD Truck Springs that offer a set for Corvettes.
                    Has anyone purchase from this company? Thoughts?
