Radiator Shroud # 3956109 Misalignment - NCRS Discussion Boards
  • Bob I.
    • November 9, 2006
    • 265
  • Mark E.
    • April 1, 1993
    • 4498
    Re: Radiator Shroud # 3956109 Misalignment
    Can you share photos to help understand the situation?
    Mark Edmondson
    Dallas, Texas
    Texas Chapter
    • Bob I.
      • November 9, 2006
      • 265
      Heres a look at the area of contact with the cross member and the height issue. If it would help I could remove the radiator and give you a look from the front.
      Thanks Bob
      • Mark E.
        • April 1, 1993
        • 4498
        Bob,
        It's hard to see from the photo, but the position of the shroud in my '70 looks similar to yours. The bottom of the shroud dips a bit below the top of the crossmember. And there's a small gap (maybe 1/4") between the crossmember and shroud similar to what I see in your photo.
        What's preventing the shroud extension from fitting? The notch in the extension fits around the hump on the crossmember.
        Mark Edmondson
        Dallas, Texas
        Texas Chapter
        • Sal C.
          • December 1, 1984
          • 430
          There is a lot of adjustment in that area. Are there any shims between the radiator support and the bumper cross member? If the radiator support can't be raised any more you can usually raise the shroud a bit with a little persuasion. Be mindful, however, of the gap between the top of the shroud and the radiator, where the seal goes.
          • Bob I.
            • November 9, 2006
            • 265
            • Mark E.
              • April 1, 1993
              • 4498
              So it looks like you got it?
              I didn't need to shim the core support. But the shroud is under some tension. In my current car, the top bracket was pulled forward to align the shroud with the fan while its bolts were tightened.
              Mark Edmondson
              Dallas, Texas
              Texas Chapter
