C2 differential ID - NCRS Discussion Boards
C2 differential ID
  • Michael G.
    • November 12, 2008
    • 2155
    C2 differential ID
  • Mike T.
    • January 1, 1992
    • 568
    Re: C2 differential ID
    IMG_4504.jpgIMG_4505.jpgMike - I believe that casting was used for a number of years going up to at least 1969. Can you post up a pic of the date code, found on the drivers side/bottom that should look like a letter followed by numbers. Also a pic of the stamped code on the bottom rear of the housing. It faces the ground and should start with a couple letters followed by numbers. That should tell us the date the housing was cast and the gear ratio. I've just taken a couple pics of the diff in my 65 Roadster as 'an example' to help the OP.
    Mike T. - Prescott AZ.
    • Jimmy G.
      • November 1, 1979
      • 975
      April 26 1965 Cant access what FA code is at the present time
      Casting was Jan 29 1965
      • Jim D.
        • 2882
        Joe Lucia posted in a prior thread - "The GM #3899143 carrier case was used for ALL 1967-79 Corvettes."
        Look for a casting date on the drivers side as Mike posted above.
        • Michael G.
          • November 12, 2008
          • 2155
          Here are some more pics:
          • Michael J.
            • January 27, 2009
            • 7073
            IIRC, FA is a 3.70 to 1 ratio.
            • Michael J.
              • January 27, 2009
              • 7073
              IIRC, AM is a 3.36 to 1 ratio.
              • Michael G.
                • November 12, 2008
                • 2155
                Looks like it was assembled in '67, "AM" is 3.36:1 Posi. That agrees with my measurement of the ratio. Mystified as to why the casting date seems to in be 68...though that '8' is kinda messed up...
                • Joe R.
                  • July 31, 1976
                  • 4547
                  According to the 1953-1972 Specifications Guide Special Membership Edition written by John Amgwert which was Volume 16 NUMBER 1 SUMMER 1989 lists 1965 Corvette FA as 3.70:1 Positraction 4 speed 396.
                  JR
                  • Mike T.
                    • January 1, 1992
                    • 568
                    Sorry for the confusion guys, the pics I posted of the 65 3:70 diff in my 65 NOM 396 Roadster were only meant to help the original poster see where the raised casting and stamped numbers would be located to help us identify his diff. I think some have thought they were posted by the other 'Mike'.
                    • Michael G.
                      • November 12, 2008
                      • 2155
                      We only have three Mikes on this thread, why would anyone be confused
                      • Mike M.
                        • May 31, 1974
                        • 8365
                        four mikes on this site mike Garver. u forgot saint Michael.
                        • Michael G.
                          • November 12, 2008
                          • 2155
                          Well heck, I had four Mikes at the dinner table last week....
                          • Tom D.
                            • September 30, 1981
                            • 2126
                            Mikes: Had a casting like that with a late 1962 casting date. Not sure if I still have it.
                            Seems many of the early C2s ended up with later differentials. Starting in '65, they lasted longer.
                            TD "va"
                            https://MichiganNCRS.org
                            Michigan Chapter
                            Tom Dingman
                            • Mike E.
                              • February 28, 1975
                              • 5134
