C2 differential ID
Tags: None
- Top
Re: C2 differential ID
IMG_4504.jpgIMG_4505.jpgMike - I believe that casting was used for a number of years going up to at least 1969. Can you post up a pic of the date code, found on the drivers side/bottom that should look like a letter followed by numbers. Also a pic of the stamped code on the bottom rear of the housing. It faces the ground and should start with a couple letters followed by numbers. That should tell us the date the housing was cast and the gear ratio. I've just taken a couple pics of the diff in my 65 Roadster as 'an example' to help the OP.Mike T. - Prescott AZ.- Top
Here are some more pics:
E35C7144-9AD2-4487-9D30-CEDA13A21540.jpg- Top
IIRC, FA is a 3.70 to 1 ratio.Big Tanks In the High Mountains of New Mexico- Top
IIRC, AM is a 3.36 to 1 ratio.Big Tanks In the High Mountains of New Mexico- Top
Looks like it was assembled in '67, "AM" is 3.36:1 Posi. That agrees with my measurement of the ratio. Mystified as to why the casting date seems to in be 68...though that '8' is kinda messed up...- Top
Sorry for the confusion guys, the pics I posted of the 65 3:70 diff in my 65 NOM 396 Roadster were only meant to help the original poster see where the raised casting and stamped numbers would be located to help us identify his diff. I think some have thought they were posted by the other 'Mike'.Mike T. - Prescott AZ.- Top
- Top
- Top
Mikes: Had a casting like that with a late 1962 casting date. Not sure if I still have it.
Seems many of the early C2s ended up with later differentials. Starting in '65, they lasted longer.
TD "va"https://MichiganNCRS.org
Michigan Chapter
Tom Dingman- Top
