'63 Horn Wiring Color Green or Black? - NCRS Discussion Boards
  • Frederick H.
    • August 31, 1983
    • 398
    I searched the Forum and the Judging Manual but was unable to find info on correct color for the harness wiring that connects to the 455 and 456 horns. My original harness wires are green but the ones from M&H are black. Mine is a late March car - anyone know if and when there was a change? If they have to be green, any tricks on changing?
    Thanks in advance.
  • Mike M.
    • May 31, 1974
    • 8365
    Re: '63 Horn Wiring Color Green or Black?
    all midyears I've restored over the years had GREEN wires to their horns. mike
    • John D.
      • December 1, 1979
      • 5507
      Fredrick, I had the same problem. Original harness was/is green. John
      • Frank D.
        • December 27, 2007
        • 2703
        My late May car has green wire in that spot and always has...
        My Doc Rebuild wiring diagram also shows a green wire.
        • Joe R.
          • July 31, 1976
          • 4547
          The original color of the horn wire was GREEN!
          JR
          • Frederick H.
            • August 31, 1983
            • 398
            Does anyone have any ideas as to how to correct?
            • Mike M.
              • May 31, 1974
              • 8365
              if u dont have any green wire, I can cut a piece off an old original headlight harness and send it to you(free). then u can splice it into your incorrectly colored repo harness. mike
              • Alan D.
                • January 1, 2005
                • 2027
                Well I'm going with black (I'm out on a limb here so hope somebody can educate me)
                The 63AIM, Sect 12 sheet A8.00 calls for Black and the 63 Shop Manual page 12-28 fig 41a shows 14-B
                and I do recall black being correct.
                  • 6940
                  Alan, i believe you may be correct, my 63 has its original harness, horn wires are black. that may have changed in 64??
                  • Alan D.
                    • January 1, 2005
                    • 2027
                    Ed, definitely for 64 it became DG (dark green?) it's not what I would call dark but it is green! Both the AIM and Shop Manual show it as such. Believe I've been through this discussion before just can not recall when or where. ty
                    • Frederick H.
                      • August 31, 1983
                      • 398
                      Thanks Mike. I still have my original harness so will have to decide whether to "hide a splice" or leave as is and take the hit if/when it gets judged.
                      THanks,
                      Fred
                      • Mike M.
                        • May 31, 1974
                        • 8365
                        FRED: I NOT LONGER Have any63 vet to check the color of horn wire. hold off on splicing a green wire till more folks chime in. mike
                        • Alan D.
                          • January 1, 2005
                          • 2027
                          Did a little checking on 58 - 62 wiring diagrams, they all show the horn wiring was black. One can assume GM continued to used a black wire through 63 for the horns. Now why the change in 64 up?? New standard??
                          Also note the JG, pg 134: "Horn wires are normally black in 1963 but may possibly be green in late models. All 1964 horns wires are green."
                          So if the concern is what to use for judging on your 63 - would go with black!
                          • Peter H.
                            • April 1, 1980
                            • 223
                              • 6940
                              I have two 63’s in garage both have black wires on horns. column lead is also black on one car the other had a service replacement and is green.
