71 tie rod end - NCRS Discussion Boards
71 tie rod end
  • Robert G.
    • April 13, 2017
    • 72
    71 tie rod end
  • Ron G.
    • December 1, 1984
    • 865
    Re: 71 tie rod end
    Robert,
    Just curious what is the build date of your car?
    - Ron
    "SOLID LIFTERS MATTER"
      • 6940
      Re: 71 tie rod end
      Bob, if there is nothing wrong with them I would leave them alone some of the reproduction and after market parts are made in China, those parts I am sure they are 50 years and have lasted this long.as much as we drive these cars they will last another 50. GM made some good suspension and steering parts in the days these cars were made. Just clean them up and reuse.
      • Robert G.
        • April 13, 2017
        • 72
        Re: 71 tie rod end
        Hi Ron,
        The trim tag date is September 9th, 1970
        • Robert G.
          • April 13, 2017
          • 72
          Re: 71 tie rod end
          Thank you Ed. That is music to my ears.
          • Mike E.
            • February 28, 1975
            • 5134
            Re: 71 tie rod end
            That looks very much to me like they could be the originals. Does the yellow paint appear to be factory-installed? If so, that clearly would be another vote for originality.
              Re: 71 tie rod end
              Originally posted by Robert Gallo (63502)
              Hello,
              I have a couple of tie rod questions.
              1- Do the tie rod ends in the photo appear original? They are from my 1971, (71,000 mi) and I don’t know if they have been replaced.
              2- I may want to replace them, if so , any vendor recommendations would be appreciated. Paragon’s are about 2x the cost vs. some of the other big vendors. This is for a car that will be judged.
              3) can you confirm what numbers/letters originals be marked with please
              Thank you
              Robert-------
              Absolutely no doubt these are original ball joints or OEM replacements (there's no difference between originals and OEM GM replacements).
              Pictured are OEM tie rod ends [none for sale]. Place no importance on the forging die numbers. They could vary as there were undoubtedly multiple forging dies.
              • Gary J.
                • April 1, 1980
                • 1229
                Re: 71 tie rod end
                Joe what years does these tie rod ends apply to?
                  Re: 71 tie rod end
                  Gary------
                  All 1963-82 Corvette.
                  • Ron G.
                    • December 1, 1984
                    • 865
                    Re: 71 tie rod end
                    As someone who judges mostly chassis it is my opinion that there is no difference between tie rod ends installed on the assembly line or purchased over the counter.
                      • 6940
                      Re: 71 tie rod end
                      Robert-------
                      [ATTACH=CONFIG]102325[/ATTACH][ATTACH=CONFIG]102326[/ATTACH][ATTACH=CONFIG]102327[/ATTACH][ATTACH=CONFIG]102328[/ATTACH]
                        Re: 71 tie rod end
                        JOe sure hope you don’t run out of tie rods for your car.
                        Edward------
                        I figure I've got enough if I live to be about 300 years old. After that, though, I'm worried.
