C2 Capacitor Repair
Tags: None
- Top
Re: C2 Capacitor Repair
Besides Delco-Remy Made in USA is there a number stamped on the end of the capacitor?- Top
Mike Andresen
Bloomington, IL- Top
A new replacement capacitor may not have the #1960960 stamped on the end. I would try to find a good used original.- Top
Thanks Stewart. That was what I was thinking of doing. My plan is to strip a small amount of insulation from the wire. It appears there is some remnant of wire down inside of the capacitor. My plan is to clean that out with a small drill to create a good opening for the solder and the wire. Did you do something similar? I assume you have to work quickly after the solder goes into the hole. Any tips?Mike Andresen
Why worry about repairing one when a couple are available to you?
Any one of these will work on any C-2 with a radio.
JR
IMG_0301[1].jpg- Top
- Top
