I recently replaced the rear leaf spring mounting hardware and am wondering if the rubber cushions and large washers that I took off are original factory installed parts or older replacement parts. I am trying to determine if these had been changed before because it's a 49K original mile car and the rubber is old, but not breaking down like I would think they would do.
All four cushions have a molded in ABF as shown. The washers have a stamped in "made in Canada" with another arrowhead type stamp with what appears fo be CMJ on the same side. Are these factory originals? The four cup guides are clearly original to the car based on how rough they are and the AFB from the cushions is embedded into the surface gunk. Opinions?
