Need specs for GM #181365 - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
  • Tom E.
    • June 1, 2019
    • 448
    Re: Need specs for GM #181365
    Gary,
    I didn’t take measurements when I restored my 67 but the bolt securing the Idler Arm to the frame bracket was original and untouched on my car. They were black phosphate. And, if memory serves me correctly, they were fine thread, not the -16 coarse thread. Image taken during disassembly.
    Tom
    • Gary B.
      • February 1, 1997
      • 6979
      • Tom E.
        • June 1, 2019
        • 448
        Gary,
        You are correct on the bottom bolts and corresponding steering box bolts. Hard to see in the photo because of years of grime but there are nuts and lock washers on the 3 carriage bolts, which were also black phosphate and well protected by steering box grease leaked out over the years.
        Tom
        • Richard M.
          Super Moderator
          • August 31, 1988
          • 11302
          Gary,
          I believe all 1967 AIMs are missing that UPC 9 Sheet A2 showing the details of the idler arm and steering box, etc. Years ago John Hinckley posted that the 1966 AIM has the same info and posted a copy of it.
          As far as the upper bolt..... 181365, I see no reference to it in any P&A catalogs I have access to. But take a look at the Standard Parts section in the 38-66 P&A catalog below.....(from this thread)
          P&A Standard Parts & Hardware.pdf
          In the 3/8 bolt section it lists different part#'s for either the NC or NF 1" or 1 1/4" bolts. I'm wondering if that 181365 bolt was never available in service.
          Rich
          PS See next post for answer.......
          • Richard M.
            Super Moderator
            • August 31, 1988
            • 11302
            Gary I just did a quick search right here (181365) and found the answer from Joe. Yup, never available in Service.
            https://www.forums.ncrs.org/showthre...ghlight=181365
            Rich
            • David B.
              • March 1, 1980
              • 687
              GM # 181365 is 3/8-24 x 1!/8 plain GM 280-M class 2A thread
              • Alan D.
                • January 1, 2005
                • 2027
                These may help however from Mar64 car.
                • Gary B.
                  • February 1, 1997
                  • 6979
                  • Gary B.
                    • February 1, 1997
                    • 6979
                    Alan, David, Rich,
                    Thanks. When it comes to part number detective work, you guys are rock stars.
                    Gary
                    • Richard M.
                      Super Moderator
                      • August 31, 1988
                      • 11302
                      Gary, Just.... 181365
                      Maybe check you settings for searches, there might be something set wrong. Threads, Posts and Subforums, etc. Only thing I can think of.
                      Rich
                      • Gary B.
                        • February 1, 1997
                        • 6979
                        • Richard M.
                          Super Moderator
                          • August 31, 1988
                          • 11302
                          Gary,
                          You may have some default settings saved for Basic Search, that aren't including all posts and child forums(I.e. Subforums), etc. There are some dropdown menus embedded in the Search settings which may not search all Forums or some artifact left over from a past search. Set those parameters for All forums, and Child's, etc, and there's a Save Button to store them for further searches, Default or Advaned.
                          I think that's why it's not working.
                          Rich
                          • Gary B.
                            • February 1, 1997
                            • 6979
                            • Gary B.
                              • February 1, 1997
                              • 6979
