Need specs for GM #181365
- Top
Re: Need specs for GM #181365
Yes it is. Heres a pic of the other side of that longer boltAttached Files- Top
- Top
Gary,
FYI - Nut 9422298 in the 1970 & up Standard Parts Fasteners is listed as 3/8 - 24 Zinc.
Gary
NCRS Texas Chapter
https://www.ncrstexas.org/
https://www.facebook.com/profile.php?id=61565408483631- Top
Gary,
Thanks. For whatever reason AMK only offers a cad with wax finish for the Gr. 5 version (9422278) of that locking nut. In this and age I would have thought they would choose zinc. Maybe the original version of 9422278 was finished in cad.
Gary- Top
I just remembered I had these from a '67 I restored. Notice the nut for the 181365 bolt has 6 dots on it's periphery. At the time I considered this the original nut, along with the upper 181365 bolt and long 3820342 carriage bolt.
I believe the lower bolt attach hardware I show should have been the same locknut as on the top bolt and not the lock washer and plain nut though. At the time my '67 AIM was missing UPC 9 Sheet A2. The 1966 AIM UPC 9 Sheet A2 lower nut is not noted with the part# so it likely assumed the use of the same nut there also.
- Top
?..I believe the lower bolt attach hardware I show should have been the same locknut as on the top bolt and not the lock washer and plain nut though. At the time my '67 AIM was missing UPC 9 Sheet A2. The 1966 AIM UPC 9 Sheet A2 lower nut is not noted with the part# so it likely assumed the use of the same nut there also.
Rich- Top
