Need specs for GM #181365 - NCRS Discussion Boards
  • Gary B.
    • February 1, 1997
    • 6979
    • Dan M.
      • February 1, 2000
      • 97
      • Alan D.
        • January 1, 2005
        • 2027
        Re: Need specs for GM #181365
        And that's a power steering car, correct?
        • Gary B.
          • February 1, 1997
          • 6979
          • Dan M.
            • February 1, 2000
            • 97
            • Gary B.
              • February 1, 1997
              • 6979
              Alan,
              Which photo are you referring to?
              Gary
              • Dan M.
                • February 1, 2000
                • 97
                Yes it is. Heres a pic of the other side of that longer bolt
                  • 43193
                  Dan------
                  This is a GM #3820342. However, this bolt was phosphate-finished, not zinc or cad.
                  • Gary B.
                    • February 1, 1997
                    • 6979
                    #24
                    • Gary C.
                      Administrator
                      • October 1, 1982
                      • 17549
                      #25
                      Gary,
                      FYI - Nut 9422298 in the 1970 & up Standard Parts Fasteners is listed as 3/8 - 24 Zinc.
                      Gary
                      NCRS Texas Chapter
                      https://www.ncrstexas.org/
                      • Richard M.
                        Super Moderator
                        • August 31, 1988
                        • 11302
                        #26
                        Gary, I did some testing HERE and figured out your Search problem.....Rich
                        • Gary B.
                          • February 1, 1997
                          • 6979
                          #27
                          Originally posted by Gary Chesnut (5895)
                          Gary,
                          Gary
                          Gary,
                          Thanks. For whatever reason AMK only offers a cad with wax finish for the Gr. 5 version (9422278) of that locking nut. In this and age I would have thought they would choose zinc. Maybe the original version of 9422278 was finished in cad.
                          Gary
                          • Richard M.
                            Super Moderator
                            • August 31, 1988
                            • 11302
                            #28
                            I just remembered I had these from a '67 I restored. Notice the nut for the 181365 bolt has 6 dots on it's periphery. At the time I considered this the original nut, along with the upper 181365 bolt and long 3820342 carriage bolt.
                            I believe the lower bolt attach hardware I show should have been the same locknut as on the top bolt and not the lock washer and plain nut though. At the time my '67 AIM was missing UPC 9 Sheet A2. The 1966 AIM UPC 9 Sheet A2 lower nut is not noted with the part# so it likely assumed the use of the same nut there also.
                            • Gary B.
                              • February 1, 1997
                              • 6979
                              #29
                              ?..I believe the lower bolt attach hardware I show should have been the same locknut as on the top bolt and not the lock washer and plain nut though. At the time my '67 AIM was missing UPC 9 Sheet A2. The 1966 AIM UPC 9 Sheet A2 lower nut is not noted with the part# so it likely assumed the use of the same nut there also.
                              • Gary B.
                                • February 1, 1997
                                • 6979
                                #30
