C-2 Differential Drain Plug - NCRS Discussion Boards
  • David M.
    • December 11, 2011
    • 48
  • Richard G.
    • July 31, 1984
    • 1715
    Re: C-2 Differential Drain Plug
    A pipe tap and a replacement plug should do it.
    grease the tap so you can get most the filings out with it.
    The sign of a professional? They know when to stop before the Screw it up.
    Rick
    • Bill M.
      • 1317
      Dave
      Thats a shame the correct shouldered plugs are pretty expensive. Around $40 they are course thread so it should have been pretty hard to cross thread. I doubt much metal will dump into the oil but it would be quiet a job to clean it out if you have to. is it a posi rear? is the tag still there?
      • Frank D.
        • December 27, 2007
        • 2703
        Originally posted by Bill McMorrow (15609)
        Dave
        Good information above - and I' guess I'll tackle the elephant in the room.
        Why on God's green earth would someone take their classic car to Jiffy Lube ?
        Do your own work or find a mechanic versed on classic cars/Corvettes.
        • Gary R.
          • April 1, 1989
          • 1796
          The only plug on a stock 63-79 vette diff is the "fill" plug and 66 would have a 3/4 npt plug. I do tap real drain plugs on non NCRS type vette rebuilds and makes oil changing a simple matter.
          Every rear cover I install, new or original, I have to chase the plug holes a little. As mentioned the tapered plug should tighten well before the plug bottoms in the hole. I would remove the plug, wire brush the threads clean and see how is screws in. If you want you can use some Permatex #2 on the threads to seal it better, do not use Permatex high temp white thread sealant. It works great and I use it on other plugs I want to seal but it locks the threads like a Loctite product.
          You would expect anyone beyond 12 years old can screw in a pipe plug and snug it up without damage but that is not the case with some professional oil changers. Having a high turn over rate, low pay and most likely no benefits leaves a questionable service staff at some of those chain stores. I have seen some of the damage that some of caused, such as stripped plugs, pans, and even forgetting to add oil back in the engine.
          • David M.
            • December 11, 2011
            • 48
            Frank, good question. Convenient, but learned a valuable lesson.
            • David M.
              • December 11, 2011
              • 48
              • David M.
                • December 11, 2011
                • 48
                Bill, yes it is a posi but no tag.
                  • 6940
                  • Richard G.
                    • July 31, 1984
                    • 1715
                    The techs at Jiffy Lube just want if fast. If they can use power tools they do. Even if it's against policy.
                    And yes I bring my Truck there. Two years ago they showed me my dirty cabin air filter. I chose to have it replaced and then they found they were out of stock. So I drove to the nearest auto part place after I left Jiffy. Purchased new filters and went to put them in and they were nothing like the one they has showed me 20 min earlier.
                    Dave. I am glad you got a plan for the repair.
                    Can anyone identify this plug?
                    • Bill M.
                      • 1317
                      He said 66 so a course thread. 63 64 fine thread. Dave you may as well get the tag while you are at it.
                        • 6940
                        Thanks Bill, I was looking at the thread title.
                        • Bob R.
                          • June 30, 2002
                          • 1595
                          • Gary R.
                            • April 1, 1989
                            • 1796
                            Joe can probably confirm but I think it is from the Warren plant and used on some of the years, I have seen them before but don't recall what years had the W many have nothing.
                            • James W.
                              • December 1, 1990
                              • 2640
                              Did the fill plug on a C2 differential come from the factory with a copper sealing washer? Just curious as my '65 does not have one. I know most Corvette vendors offer them for sale.
                              James
