I'm concerned with how my '62 front end looks. At this point in reassembly, should the camber be this far off (-) centerline? At this point, I would almost expect the opposite condition.
These are original spindles, a-arms and spindle shafts (except upper outer). New aluminum shim plates are installed correctly. King pins and pivot shaft bushings have been replaced.
Does this look right at this point?
