1967 Bell Housing to Block Bolts - NCRS Discussion Boards
  • Jimmy G.
    • November 1, 1979
    • 975
    Are these acceptable??
    "M" Grade 5
    Re: 1967 Bell Housing to Block Bolts
    "M" Grade 5
    [ATTACH=CONFIG]106246[/ATTACH]
    Jimmy------
    My opinion is absolutely yes. In fact, I believe that non-trimmed ("indented") head, GM 280M (SAE 5), "M" headmark (Michigan Screw and Bolt), and zinc plated is, by far, the most common although other manufacturers' headmarkings were also likely used.
    I can't tell from the photo if the length is correct but I expect it is.
