Carburetor Date Code - NCRS Discussion Boards
  • Paul A.
    • April 21, 2021
    • 227
  • Michael H.
    • December 1, 1987
    • 724
    Re: Carburetor Date Code
    What is the build date of your engine ? I would look for 30-90 days from build date of the engine. You can go back as much a 6 months but that's not typical.
    • Paul A.
      • April 21, 2021
      • 227
      Yes of course engine build date. Thanks for that info Micheal.
      • Paul A.
        • April 21, 2021
        • 227
        Engine build date A19 6
        Carb date code 5B 4
        Would that be to soon, or acceptable for judging?
        • David H.
          • June 30, 2001
          • 1485
          Carb date code 5B 4
          Paul
          Typically, 3 digit Holley codes are Year / Month / Week (Link Below)
          https://www.holley.com/blog/post/hol...unter_s_guide/
          Are you sure your "B" is not an "8"?
          or 1965 / August / 4th week
          What is the "List" number on your carburetor? (Holley Part Number)
          Dave
          3882835 (or 3892341 for cars with air injection reactor)
          Judging Chairman Mid-Way USA (Kansas) Chapter
          • Michael H.
            • December 1, 1987
            • 724
            Carb date code 5B 4
            Paul,
            That A 19 6 must be a casting date of the block which is Jan 19th 1966. What is the date on the engine stamp pad ? So you want a carb dated in Nov. or Dec. of 1965 would be ideal.
            The 5 B 4 is really close Dec 4th week, but it should work OK. I would like to see 5 B 1 or 5 B 2.
            Just my .02
            Mike
            • Michael H.
              • December 1, 1987
              • 724
              Originally posted by David Houlihan (36425)
              Paul
              Dave
              Dave,
              "A" was used for Nov and "B" was for Dec.
              Month Code
              Jan. ------------- 1
              Feb. ------------- 2
              Mar. ------------- 3
              Apr. ------------- 4
              May ------------- 5
              Jun ------------- 6
              Jul ------------- 7
              Aug ------------- 8
              Sep ------------- 9
              Oct ------------- 0
              Nov ------------- A
              Dec ------------- B
              Mike
              • David H.
                • June 30, 2001
                • 1485
                Dave,
                "A" was used for Nov and "B" was for Dec. ... Mike
                Mike
                Thanks. Just checking - "B" and "8".
                Dave
                • Paul A.
                  • April 21, 2021
                  • 227
                  Paul,<br />
                  <br />
                  That A 19 6 must be a casting date of the block which is Jan 19th 1966. What is the date on the engine stamp pad ? So you want a carb dated in Nov. or Dec. of 1965 would be ideal.<br />
                  The 5 B 4 is really close Dec 4th week, but it should work OK. I would like to see 5 B 1 or 5 B 2.<br />
                  <br />
                  Just my .02<br />
                  <br />
                  Mike
                  <br />
                  <br />
                  T0207IL
                  • Larry M.
                    • January 1, 1992
                    • 2688
                    Engine build date has nothing to do with the carb date...........as engines were all built and test fired without the carb in place. Butane or similar was used for test firing. Carb was first installed at St Louis.
                    Ideally I would like the carb dated about 2-6 weeks prior to the CAR build date, based upon the car's VIN. NCRS allows six months prior to car build date, but that is excessive.
                    Larry
                    • David H.
                      • June 30, 2001
                      • 1485
                      Paul
                      What is the part number on your carburetor?
                      Dave
                      • Paul A.
                        • April 21, 2021
                        • 227
                        Paul
                        Dave
                        3882835-EO
                        List 3370
                        5B4
                        • David H.
                          • June 30, 2001
                          • 1485
                          3882835-EO
                          List 3370
                          5B4
                          Paul
                          Looks like you are good to go re part number and date.
                          Dave
                          • Larry M.
                            • January 1, 1992
                            • 2688
                            3882835-EO
                            List 3370
                            5B4
                            The date code "5B4" translates to 1965, December, 4th week of December. This is a perfect match for a car built in mid February 1966. You are "golden".
                            Larry
