Vinnie Peters did a remarkable job turning my abstruse, rambling, and mostly incomprehensible text into something readable in the current issue of the Restorer. Thank you, Vinnie!!
There are two points, however, I would like to clarify:
1. I don't advocate insulating fuel lines. My temperature measurements failed to uncover any benefit in doing so. If you look at the last photo in the article, the one of my mongrel, modified FI unit, you'll see there is no insulation anywhere.
2. The graph which shows how much longer it took for the onset of fuel percolation relates ONLY to the effect of recirculating fuel using stock, copper fuel lines. Since I converted my mongrel FI to have steel fuel lines and nylon nozzle block retainer bolts I haven't experienced fuel percolation at all. Not once. Not a single time, even when ambient temps were around 97 degrees.
For those who have emailed me since the publication of the article, thank you all for your kind, encouraging words.
Jim
Edit: For what it's worth, the attached picture shows the copper fuel line configuration which was in use when I collected the data for the article's graph.
Jim
