Remove 63 parking brake cables - is there a trick? - NCRS Discussion Boards
    • 11608
    #31
    Re: Remove 63 parking brake cables - is there a trick?
    I had to wiggle it a bit.
    You can remove the drums on the rear and get a better view of the procedure, as the clips are the same.
    • Gerald C.
      • June 30, 1987
      • 1273
      #32
      I did take the drum brake end of the cables with a small clamp. Came right out. Still having issues with the chassis end. " I wiggled till I can't wiggle no more!" I'll keep playing with it.
      Thanks.
      • Gerald C.
        • June 30, 1987
        • 1273
        #33
        Well, I went to a 1/2" plastic piping and honed out the center a bit. The OD barely fit inside the chassis hole, but I honed out the ID enough to get it over the cable. It fit snugly, but it did release the cables from the chassis.
        Finally, a success!
        Thanks everyone for their suggestions!
