Wiper Weirdness - NCRS Discussion Boards
Wiper Weirdness
  • Jack W.
    • August 31, 1995
    • 126
    Wiper Weirdness
  • Joe R.
    • July 31, 1976
    • 4547
    Re: Wiper Weirdness
    Jack,
    There was an article published in The Restorer Volume 35, Number 2 by Mike Poirier. Following those guidelines you should be able to diagnose your wiper switch. Just remember the switch supplies grounds to the wiper motor and has to be grounded in the instrument cluster before it will function correctly. The ground for the motor is supplied via a ground wire directly to the motor.
    JR
    • Jack W.
      • August 31, 1995
      • 126
      Re: Wiper Weirdness
      Joe,
      Thanks a bunch. I wondered about the ground to dash possibility.
      I will check that article as you suggest.
      Great to hear from you.
      Best,
      Jack
      • Frank E.
        • May 31, 1986
        • 189
        Re: Wiper Weirdness
        If the motor is original and has never been serviced, you might want to pop the cover off and clean out all of the old grease and re-grease it. On mine , after turning the wiper switch on, it would take some time to begin wiping. Found all of the grease was really hard so I cleaned it all out (on the car) re-greased and its been working like a champ ever since....
        Frank
        1966 Milano Maroon Roadster
        2004 CE Z06
        • Jack W.
          • August 31, 1995
          • 126
          Re: Wiper Weirdness
          • Frank E.
            • May 31, 1986
            • 189
            Re: Wiper Weirdness
            I think I just used a good lithium based white grease.
            Frank
            2004 CE Z06
              • 15610
              Re: Wiper Weirdness
              White lithium grease dries out too fast. Use a synthetic based grease like Mobil 1 and use it sparingly. Just coat the moving parts, but don't "pack" the entire housing.
              • Jack W.
                • August 31, 1995
                • 126
                Re: Wiper Weirdness
                Got it! Thanks!!
                Jack
                • Jack W.
                  • August 31, 1995
                  • 126
                  • Jack W.
                    • August 31, 1995
                    • 126
                    • Mark F.
                      • July 31, 1998
                      • 1468
                      Re: Wiper Weirdness
                      Loose dead short to the hot side somewhere inside the wiper motor or harness (bypassing switch)?
                      thx,
                      Mark
                      • Jack W.
                        • August 31, 1995
                        • 126
                        Re: Wiper Weirdness
                        • Frank E.
                          • May 31, 1986
                          • 189
                          Re: Wiper Weirdness
                          You know Jack, it sure sounds like you have some old grease inside the motor. Did you take the cover off the motor at the firewall and clean out all of the old grease and re-grease the mechanism????
                          Frank
                          2004 CE Z06
                          • Jack W.
                            • August 31, 1995
                            • 126
                            • Grant M.
                              • August 31, 1995
                              • 448
                              Re: Wiper Weirdness
                              This may not be the same as you are experiencing, but on my 65 the wiper switch is the culprit for sporadic operation and stopping of the wipers. the twist knob seems to be 'loose' inside the switch and one has to move it back and forth until the wipers work and then the same to get them to park. I have a new switch and just have to get the car back from transmission rebuilder to install it and see what happens.
