Radiator fins 71 Lt-1 finish
Re: Radiator fins 71 Lt-1 finish
Robert------
Yes, the fins are painted with the rest of the radiator. Radiator paint is available from Eastwood and others that's a reasonably good match.In Appreciation of John Hinckley- Top
The radiator paint was likely applied by the radiator assembly plant in Rochester New York. I doubt the radiator was installed in the car until after black out.
Joe L: do you have additional information on these details? Anyone else???Terry- Top
Terry------
Yes, the radiators were definitely painted at the radiator manufacturing plant. The plant was in Lockport, New York. In fact, it's still there having been once "spun-off" as part of DELPHI (the "H" in DELPHI represents Harrison Radiator) but later separated from DELPHI and returned to the GM fold.In Appreciation of John Hinckley- Top
Thanks for the update Joe. I was pretty comfident you would have information to add. I should have known it was Lockport.Terry------
Anything to add about if the radiator was installed before black-out? I can't imagine the black-ot got to the front of the core support with the radiator in place and I can't picture the worker reaching over the radiator and core support without getting the black-out in more places than we see.Terry- Top
Terry------Thanks for the update Joe. I was pretty comfident you would have information to add. I should have known it was Lockport.
I suspect but do not know that the radiator was installed after black-out.In Appreciation of John Hinckley- Top
- Top
