2 B-28's from rock auto showed up today. Along with a new mityvac gauge. Both units tested out starting around 4 and all in at 8.
Tested the unit in the LT-1 figuring it was leaking, but got same results. And it's holding vacuum.
My issue is when I pull the vacuum hose there's vacuum at the hose. (Have it attached to manifold vacuum)When plugged into the B-28 there is no difference in idle.
Pulling the cap I watched as vacuum is applied, the magnetic pickup rotates counterclockwise. The centrifugal advance doesn't move, unless i move it by hand clockwise.That correct?
