Re: B-28 follow up
Using rubber band method to restrict centrifugal advance.
Can the amount of centrifugal advance coming in at idle be determined given the data in the pics? Timing 12 degrees btdc at the crank.
Vacuum attached no rubber band
Vacuum attached rubber restricting weights
Gauge tee's. No change either way
