My 57 leaks rear end oil, left side, slow leak drips down the axle housing/backing plate interface area. Inside of backing plate - brake shoe area is dry. Right side is fine.
I have replaced the bearing o-ring - still leaks.
Could this be the bearing? Probably original, but spins fine, no noise anywhere.
I think it is leaking around what looks like a vent hole in the bottom of the backing plate - the gasket is notched for it and the axle retainer plate is too. But why is a vent hole required here?
If the bearing, looks like a tough job to replace. My son-in-law has a good hydraulic press, but would need to fab a special tool of some kind to pick up the bearing inter race.
If I have to replace the bearing, are the ones from our suppliers okay, or are they off-shore junk.
I have it apart right now, but would like to get it fixed and back together fairly soon.
Appreciate any help.
Dan D.
Dan D.
