C2 Headlight motor internal - NCRS Discussion Boards
  • Ron L.
    • July 31, 1998
    • 111
    Anyone out there have a picture or schematic of their breakdown of washers, etc. on the armature shaft? My motor runs one direction and not the other. Mechanic friend has determined that if you press down on the geared portion of the motor, it will spin both ways. That leads me to believe that the person who rebuilt the motor failed to put in a brass washer or two on the shaft side plate next to the gear box. Any thoughts?
  • Richard M.
    Super Moderator
    • August 31, 1988
    • 11302
    Re: C2 Headlight motor internal
    Ron, See the Sticky threads above...
    Database of Restoration Documents.
    Main Page, scroll down list to "Headlight".
    This one has details.
    "C2 Headlight Motor Rebuild"
    Also, click on "Update Page". In there I have one that adds to the above.
    "C2 Headlight Motor Diagnosis 11-15-20.pdf"
    If the motor runs only in on direction yes it may be getting jammed up. Could be several reasons, including a problem with field coil too.I'd remove the big plastic gear assy, reassemble it and run the motor "no load" both ways to see if it's a electrical or mechanical fault.
