Re: Anti-siphon installation, T.I., and judging
Jim, He had no power during CRANK with it connected to the ACC circuit, yet he said the engine still started. Since it's impossible to get fuel flow through it under those conditions, my brain was trying to figure out how fuel got through the spider to the nozzles to run without power on it to open, a possible case being if the valve was stuck open it might be a way for the engine to run. Yes I follow, it'll start too easy in that scenario as it's like there's no ASSV there at all.
Bend a rod? Because the valve is stuck open? You mean if the fuel meter check valve is stuck open or missing, too, and the thing dumped raw fuel down and filled some cylinders? No anti-siphon solenoid valve means plain stock, no?
Rich
Rich
