�69 wiper works when the fuse is not fully seated
Check both the fuse and the spring clips on the fuse block for corrosion. There is also a chance that the spring clip on one side has lost its tension. This will happen if there is corrosion and the connection heats up. If that clip has lost its tension O am not sure there is a solution to lost tension except replacement and that is a royal pain. Best to hope and pray it is just corrosion and that you caught it soon enough.Terry- Top
