�69 wiper works when the fuse is not fully seated - NCRS Discussion Boards
  • Steven B.
    • June 30, 2004
    • 256
  • Stephen L.
    • May 31, 1984
    • 3148
    • Steven B.
      • June 30, 2004
      • 256
      Originally posted by Stephen Lavigne (7553)
      Probably slight corrosion on the fuse and holder..... clean it off and try again.......
      Thanks Stephen, I'll pull it and give that a shot. I appreciate it.
        • 15573
        Check both the fuse and the spring clips on the fuse block for corrosion. There is also a chance that the spring clip on one side has lost its tension. This will happen if there is corrosion and the connection heats up. If that clip has lost its tension O am not sure there is a solution to lost tension except replacement and that is a royal pain. Best to hope and pray it is just corrosion and that you caught it soon enough.
          • 6940
