1954 corvette distributor ground wire - NCRS Discussion Boards
  • Fred L.
    Infrequent User
    • February 1, 2001
    • 3
    The wiring diagram shows a ground wire at the distributor but does not designate the starting point or the termination point??
  • Chris S.
    • January 1, 2000
    • 1064
    Re: 1954 corvette distributor ground wire
    There is a pink wire from the ignition switch thru the firewall to a capacitor at the ignition shielding - on the back side it switches to a black wire that goes to the + side of the coil. There is a block on the side of the distributor that a black wire goes to the - side of the coil - Chris TiN Restorations
    1954 Corvette #3803 - Top Flight 2012, Bloomington Gold 2012,
    Triple Diamond Award 2012, Gold Concourse Award 2012, Regional and National Top Flight 2014
    1954 Corvette #3666 - "The Blue Devil" - Pennant Blue - restoration started
    1957 Corvette - FI 3 sp - Black and Silver
