327 Hydraulic Lifter failure (broken)
Re: 327 Hydraulic Lifter failure (broken)
WOW I have seen destroyed lifters BUT never one like that!
Any estimate on the miles put on the engine since rebuild?James A Groome
1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453- Top
I haven't seen this before either.
Perhaps shear failure due to a material defect, and/or repeated torsional load from the cam combined with the lifter sticking in its bore. Just a hypothesis.Mark Edmondson
Dallas, Texas
Texas Chapter
1993 Coupe, 40th Anniversary, 6-speed, PEG 1, FX3, CD, Bronze Top- Top
What does the cam lobe look like? If a piece broke off of it, it likely caused the lifter to wear down like that.
I suspect it took some time to wear, then finally destroyed itself at 5 grand.- Top
Update here. Engine was pulled this morning and cam removed. Two pictures below show the damaged lobe. Further tear down of mains and rod bearings showed no wear or foreign material! Gotta love the Wix filter cartridges for these earlier small blocks. I have purchased and installed a Melling 22210 cam and new lifters. Of coarse everything was cleaned up real good before reassembly.
I do have one question concerning the balancer. It is the factory thin balancer and I was thinking of stepping up to a new balancer. Thoughts anyone? As a side note I am now runnning Edelbrock E-Street heads with 2.02 intakes and 1.60 exhaust. Also have a set of 1.6 roller rockers. Flat top pistons at advertised 10:1 ratio. looking for input.IMG_8972.jpgIMG_8973.jpgJohn Seeley
67 Black/Teal
300 hp 3 speed coupe
65 Maroon/Black
35k mile Fuelie coupe- Top
