327 Hydraulic Lifter failure (broken) - NCRS Discussion Boards
  • John S.
    • May 4, 2008
    • 424
    John Seeley
    67 Black/Teal
    300 hp 3 speed coupe
    65 Maroon/Black
    35k mile Fuelie coupe
  • James G.
    • August 22, 2018
    • 783
    Re: 327 Hydraulic Lifter failure (broken)
    WOW I have seen destroyed lifters BUT never one like that!
    Any estimate on the miles put on the engine since rebuild?
    James A Groome
    1971 LT1 11130 - https://photos.app.goo.gl/zSoFz24JMPXw5Ffi9 - the black LT1
    1971 LT1 21783 - 3 STAR Preservation.- https://photos.app.goo.gl/wMRDJgmyDyAwc9Nh8 - Brandshatch Green LT1
    My first gen Camaro research http://www.camaros.org/forum/index.p...owposts;u=4337
    Posts on Yenko boards... https://www.yenko.net/forum/search.php?searchid=826453
    • Mark E.
      • April 1, 1993
      • 4498
      I haven't seen this before either.
      Perhaps shear failure due to a material defect, and/or repeated torsional load from the cam combined with the lifter sticking in its bore. Just a hypothesis.
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Richard M.
        Super Moderator
        • August 31, 1988
        • 11302
        What does the cam lobe look like? If a piece broke off of it, it likely caused the lifter to wear down like that.
        I suspect it took some time to wear, then finally destroyed itself at 5 grand.
        • John S.
          • May 4, 2008
          • 424
          John Seeley
          67 Black/Teal
          65 Maroon/Black
          • John S.
            • May 4, 2008
            • 424
            Update here. Engine was pulled this morning and cam removed. Two pictures below show the damaged lobe. Further tear down of mains and rod bearings showed no wear or foreign material! Gotta love the Wix filter cartridges for these earlier small blocks. I have purchased and installed a Melling 22210 cam and new lifters. Of coarse everything was cleaned up real good before reassembly.
            I do have one question concerning the balancer. It is the factory thin balancer and I was thinking of stepping up to a new balancer. Thoughts anyone? As a side note I am now runnning Edelbrock E-Street heads with 2.02 intakes and 1.60 exhaust. Also have a set of 1.6 roller rockers. Flat top pistons at advertised 10:1 ratio. looking for input.IMG_8972.jpgIMG_8973.jpg
            John Seeley
            67 Black/Teal
            65 Maroon/Black
