First question relates to door weatherstrip, does the slit @ the bottom have molded shut ends? I was thinking of cutting with a razor, but do not want to cut if this is not correct, was there a big gap? Second question is door sill screw heads, does anyone know of a vendor that makes the correct small head black crews? Thanks for your help.
A couple of judging questions for 70/72
Re: A coupe of judging questions for 70/72
1. Slice away, that's how the factory did it. The weatherstrip was delivered as one piece, and the installers sliced it into two on the line to make it easier to install. As a result the gap was irregular and not necessarily straight. I have also seen a factory original car where the slice did not quite go all the way through.First question relates to door weatherstrip, does the slit @ the bottom have molded shut ends? I was thinking of cutting with a razor, but do not want to cut if this is not correct, was there a big gap? Second question is door sill screw heads, does anyone know of a vendor that makes the correct small head black crews? Thanks for your help.
2. No, not offhand.Vice-Chairman (West), Michigan Chapter NCRS
I bought new sill plates from Corvette America that came with new screws which appear correct to me. I have not had my car judged yet. They sell the screws without the sill plates:
https://www.topflightautomotive.com/...w-set-8-piece/
Good luck,
Allen- Top
I should let everyone know Reba Whittington sent me a message, screw size was 10 with a #8 head. I googled and found a box.New England chapter member, 63 Convert. 327/340- Chapter/Regional/national Top Flight, 72 coupe- chapter and regional Top Flight.- Top
