Distributor questions
Re: Distributor questions
65 big block distributors had an oiling groove that was not continuous around the diameter, but I think it was the was same as small blocks in 66 and certainly in 67 when the rear cam bearing was changed and the cam groove discontinued. At any rate this did not affect the electric operation. If you are replacing a big block distributor with a small block unit with a different groove pay attention to the oil pressure, but there will probably not be a change,- Top
Don Harris
Former: 60 Red/Red, 2x4, 245hp (Regional and National Top Flight 2013), 66 coupe Nassau Blue, L79 (Chapter and Regional Top Flight 2017)- Top
Don------I’m helping with a 66 big block with starting issue.
I believe I read somewhere that big block distributors have a special oiling groove near the end.
Is this true? If so, does the 390 HP use that distributor or does it use the same distributor as a small block?
Don
GM says that the distributor housing with the "full round" oil groove can be used for all 1962-74 Corvette applications.In Appreciation of John Hinckley- Top
It was bad coil.Don Harris
