Distributor questions - NCRS Discussion Boards
  • Donald H.
    • November 2, 2009
    • 2580
    Don Harris
  • Patrick B.
    • August 31, 1985
    • 1986
    Re: Distributor questions
    65 big block distributors had an oiling groove that was not continuous around the diameter, but I think it was the was same as small blocks in 66 and certainly in 67 when the rear cam bearing was changed and the cam groove discontinued. At any rate this did not affect the electric operation. If you are replacing a big block distributor with a small block unit with a different groove pay attention to the oil pressure, but there will probably not be a change,
    • Donald H.
      • November 2, 2009
      • 2580
      Don Harris
      • Patrick B.
        • August 31, 1985
        • 1986
        • Ed H.
          • November 1, 1999
          • 626
          Donald check your coil if all else is in good working order.
          • Donald H.
            • November 2, 2009
            • 2580
            Ed, yes that is on my list of things to check. I have a good spare coil in hand just in case.
            Don
            Don Harris
            • George J.
              • March 1, 1999
              • 774
              Don
              And a condenser. Try a new one with the working coil.
                • 43193
                I’m helping with a 66 big block with starting issue.
                I believe I read somewhere that big block distributors have a special oiling groove near the end.
                Is this true? If so, does the 390 HP use that distributor or does it use the same distributor as a small block?
                Don
                Don------
                GM says that the distributor housing with the "full round" oil groove can be used for all 1962-74 Corvette applications.
                • Donald H.
                  • November 2, 2009
                  • 2580
                  It was bad coil.
                  Don Harris
