Volume of aluminum 842 heads from the factory.
Re: Volume of aluminum 842 heads from the factory.
Google to the rescue again. Check out https://garage.grumpysperformance.co...asting-s.3960/
it says 107cc.
Gaty- Top
- Top
Thank you Joe!
I just did a search on the other forum and only found one mention of the volume for the 842 heads and that person said he thinks it’s 106cc
For such an important component of engine building, surprised there isn’t more info out there- Top
If you have nice unmilled heads and the volume is greater than 106.8, you should not worry. 106.8 might be spec for competition blueprinting that allows for some surface milling. My 67 L89 392 heads were about 106 but they had definitely been milled.- Top
- Top
