72 BB Vacuum Spark Tube - NCRS Discussion Boards
  • Anthony D.
    • August 31, 2005
    • 108
    I searched every vendor at Carlisle and the repro vendors and cannot find the metal vacuum tube that runs from the distributor, cec solenoid to the carb, smog divertor.
    Thanks!
  • Ronald L.
    • October 18, 2009
    • 3248
    Re: 72 BB Vacuum Spark Tube
    part number
    pics
    etc
    Carlisle isn't the place for hard to find parts anymore
    • Mark E.
      • April 1, 1993
      • 4498
      Check Doc Rebuild. He used to sell vacuum advance lines and hose kits for specific applications.
      As a photo reference, Google is your friend if the JG doesn't have a picture (which it probably does).
      Mark Edmondson
      Dallas, Texas
      Texas Chapter
      • Anthony D.
        • August 31, 2005
        • 108
        1. View from the aim. P/n 626965.
        2. Bought the hose kit from Doc. No tubes in stock, though he provides a straight tube you have to bend yourself.
        3. I have lots of pics, wanted to come close to factory, will have to bend something up.
        Thanks all!
        • Ronald L.
          • October 18, 2009
          • 3248
          You’re looking for the Spark Control Pipe? Good view
          No part number. Is it shown or referenced on a different sheet?
          the number you gave is not a GM number
          • Anthony D.
            • August 31, 2005
            • 108
            Item 3
            • Ronald L.
              • October 18, 2009
              • 3248
              Originally posted by Anthony Dusovic (44491)
              Item 3
              [ATTACH=CONFIG]123548[/ATTACH]
              Which suppliers have yopu already asked?
              CC-Paragon?
              Did you look in an old Paragon catalog?
              • Tom L.
                • October 17, 2006
                • 1439
                I have one that I used as a template to bend a new one. I'll dig it out and get you as much info on it as I can. This is an impossible part to find. I got lucky. The other thing that's almost impossible to get is the rear clip for it. Not reproduced. Only the forward one is since it's used on many other applications.
                • Owen L.
                  • September 30, 1991
                  • 838
                  Thank you, Tom. If the pipe sits flat on a scanner, that type of file would be fantastic. Or a straight down photo on a grid background. (I need the pipe too.)
                  • Anthony D.
                    • August 31, 2005
                    • 108
                    That would be great Tom. I ordered 2 repro clips from Doc rebuild hoping to bend on up for the rear. Id appreciate a picture of that also.
                    much appreciated!
                    • Ronald L.
                      • October 18, 2009
                      • 3248
                      Was Corvette the Only usage?
                      Or was this used on all the 454 of this era?
                      • Tom L.
                        • October 17, 2006
                        • 1439
                        PM me your cell number, will be easier to share pics that way.
                        • Anthony D.
                          • August 31, 2005
                          • 108
                          Not a clue.
                          • Ronald L.
                            • October 18, 2009
                            • 3248
                            Really - happy bending.
                            • Mark E.
                              • April 1, 1993
                              • 4498
                              For what it's worth, I got reproduction clips for a '70 LS5 from a Camaro/Chevelle parts vendor.
                              Mark Edmondson
                              Dallas, Texas
                              Texas Chapter
