Vacuum switch - NCRS Discussion Boards
Vacuum switch
  • Mike G.
    • January 1, 1991
    • 418
    O-ring
    This goes back a few years, but I recall not being able to find an O-ring with the correct OD, so I custom sized a batch by slipping them on a nail, chucking the nail in my drill, and sanding them down with wet/dry 400grit.
    Be sure to use vacuum grease when reassembling. Still working fine...
    Thanks Doc for this hint in your excellent catalog!
    By the way, I see a Mustang heater vacuum switch on eBay that's the same basic configuration. Plastic case though.
    • Bob L.
      Infrequent User
      • December 1, 2004
      • 17
      Re: Vacuum switch
      My switch was frozen when I bought the car (66) 327/300....valve was also missing.....I replaced the Vacuum switch, Vac. lines & Valve all from LIC...all in working order...only problem now is that I can' get the A/C to blow cold....... but that's just another project........
