electronic unit
- Top
Re: electronic unit
Lyndon,
If you replaced the ignition points with an electronic pickup, I would guess that the chances of getting the pickup to trigger the ignition in exactly the same place, in degrees, that the point set did, are near zero.
Moving the pickup position would produce the same results as rotating the distributor housing which changes the ignition timing.- Top
